Ir para o conteúdo principal
Dell G15-5510 Gaming SSD Replacement
Clay Eickemeyer
Clay Eickemeyer e 2 outros colaboradores
Última atualização em June 16, 2023
15 - 30 minutos
Moderado
Introdução
Ir para o passo 1
This guide will walk you through the process of replacing the SSD in your Dell G15-5510 Gaming laptop.
Your laptop might not come with a standoff bracket to install an additional SSD. In this case, you'll need to purchase one.
Before you perform this repair, back up your existing SSD if possible. If you’re replacing the SSD where your operating system is installed, familiarize yourself with a disk cloning utility so you’ll be ready to migrate your data to the new SSD.
O que você precisa
Kits de conserto
Estes kits contêm todas as peças e ferramentas necessárias para executar este guia.
Peças
Ferramentas
Exibir mais…
  1. Dell G15-5510 Gaming SSD Replacement, Unfasten the back cover: passo 1, imagem 1 %32 Dell G15-5510 Gaming SSD Replacement, Unfasten the back cover: passo 1, imagem 2 %32
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Phillips #1 screwdriver to remove the four screws securing the back cover.
    • Two 8 mm screws
    • Two 5.8 mm screws
    • Loosen the four captive screws.
    On my G15 the 4 non-captive screws, marked in red and orange in this diagram, were all the same size.
    Brian Watson - Responder
  2. Dell G15-5510 Gaming SSD Replacement, Unclip the front corners: passo 2, imagem 1 %32 Dell G15-5510 Gaming SSD Replacement, Unclip the front corners: passo 2, imagem 2 %32
    • Insert an opening pick between the bottom-left corner of the back cover and the chassis.
    • Pry upward to release clips holding the cover in place.
    • Listen for a loud click to indicate a clip being released.
    Definitely important to unclip the front first and then slide the back towards you. If you try to unclip the back first, you risk damaging the small plastic flanges on the cover.
  3. Dell G15-5510 Gaming SSD Replacement: passo 3, imagem 1 %32 Dell G15-5510 Gaming SSD Replacement: passo 3, imagem 2 %32
    • Insert your opening pick again between the bottom-right corner of the back cover and the chassis.
    • Pry up to release the remaining clips securing the back cover.
  4. Dell G15-5510 Gaming SSD Replacement, Remove the back cover: passo 4, imagem 1 %32 Dell G15-5510 Gaming SSD Replacement, Remove the back cover: passo 4, imagem 2 %32 Dell G15-5510 Gaming SSD Replacement, Remove the back cover: passo 4, imagem 3 %32
    • Grip the front of the back cover and lift it away from the laptop.
    • Pull the back cover towards you to disconnect the clips along the top of the back cover.
    • Remove the back cover.
  5. Dell G15-5510 Gaming SSD Replacement, Disconnect the battery: passo 5, imagem 1 %32 Dell G15-5510 Gaming SSD Replacement, Disconnect the battery: passo 5, imagem 2 %32 Dell G15-5510 Gaming SSD Replacement, Disconnect the battery: passo 5, imagem 3 %32
    • Use the flat end of a spudger to push the battery connector's square tab away from the socket and disconnect it.
  6. Dell G15-5510 Gaming SSD Replacement, Unfasten the SSD Cover: passo 6, imagem 1 %32 Dell G15-5510 Gaming SSD Replacement, Unfasten the SSD Cover: passo 6, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the two 4.2 mm-long screws securing the copper SSD cover.
  7. Dell G15-5510 Gaming SSD Replacement, Remove the SSD cover: passo 7, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Pull the SSD cover off by hand or with a pair of blunt nose tweezers.
    • When reassembling with an 80 mm-long full size SSD, do not install this cover.
  8. Dell G15-5510 Gaming SSD Replacement, Remove the SSD: passo 8, imagem 1 %32 Dell G15-5510 Gaming SSD Replacement, Remove the SSD: passo 8, imagem 2 %32 Dell G15-5510 Gaming SSD Replacement, Remove the SSD: passo 8, imagem 3 %32
    • Grip the original SSD by the corners near the screw indent.
    • Pull it straight out of its socket and remove it.
    • Gently wiggle the SSD side to side if it feels stuck.
  9. Dell G15-5510 Gaming SSD Replacement, Remove the SSD standoff: passo 9, imagem 1 %32 Dell G15-5510 Gaming SSD Replacement, Remove the SSD standoff: passo 9, imagem 2 %32 Dell G15-5510 Gaming SSD Replacement, Remove the SSD standoff: passo 9, imagem 3 %32
    • Follow the next four steps to reposition the standoff bracket.
    • Use the flat end of a spudger to push the metal standoff bracket towards the center of the laptop and out of its slot.
    • Use a pair of blunt nose tweezers or your fingers to remove the bracket.
  10. Dell G15-5510 Gaming SSD Replacement, Reinstall the SSD standoff: passo 10, imagem 1 %32 Dell G15-5510 Gaming SSD Replacement, Reinstall the SSD standoff: passo 10, imagem 2 %32 Dell G15-5510 Gaming SSD Replacement, Reinstall the SSD standoff: passo 10, imagem 3 %32
    • Slide the bracket's standoff edge into the adjacent slot.
    • Use the flat end of a spudger to press the the bracket into the slot. The wings of the standoff will clip underneath the tabs of the slot.
  11. Dell G15-5510 Gaming SSD Replacement, SSD installation: passo 11, imagem 1 %32 Dell G15-5510 Gaming SSD Replacement, SSD installation: passo 11, imagem 2 %32 Dell G15-5510 Gaming SSD Replacement, SSD installation: passo 11, imagem 3 %32
    • Grip your 80 mm-long (M.2 2280) SSD by the corners near the screw indent.
    • Slide the SSD into the socket.
  12. Dell G15-5510 Gaming SSD Replacement, Fasten the SSD: passo 12, imagem 1 %32 Dell G15-5510 Gaming SSD Replacement, Fasten the SSD: passo 12, imagem 2 %32
    • Use your Phillips #0 screwdriver to fasten the 4.2 mm-long screw to the SSD standoff.
Conclusão
To reassemble your Dell G15, follow these instructions in reverse order.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Dell laptop answers community for help.
Uma outra pessoa concluiu este guia.
Clay Eickemeyer
Membro desde: 09/19/22
82.579 Reputação
Autoria de 455 guias
Equipe
Guide Team Membro de Guide Team
Staff
9 Membros
Autoria de 11.506 guias
1Comentário do guia
Thanks for the guide. I have the same laptop. I bought this laptop for work. I'm a game designer and create 3d character models for video games. There is a shortage of specialists in this field right now. It's good that there are services like DevotedCG, this platform unites top art professionals and a team of ADs and Producers who curate their work.
Thomas Dunk - Responder
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 23
Últimos 30 dias: 261
Ao todo: 4,313
