DeWalt D28110 Brush and Spring Replacement
15 - 20 minutos
Fácil
Introdução
Vá para o passo 1This guide will walk you through replacing the brush and spring components of the grinder. These are both located at the base of the brush motor and can be easily replaced.
O que você precisa
Ferramentas
Using the T-15 screwdriver, remove the four 22-mm torx screws holding the back panel in place.
Quase terminado!
Conclusão
