Ir para o conteúdo principal
DJI Mini 2 Drone Body Replacement
Jacob Matos
Jacob Matos e um outro colaborador
Última atualização em July 5, 2024
15 - 20 minutos
Moderado
Introdução
Ir para o passo 1
We are defining the DJI Mini 2 drone body as the top and bottom plastic panels of the drone. These panels are the blockaded between the insides of the drone and the outside world.
The drone body stores the inner electronic parts of the drone like the GPS, the Main Board, and the wires the drone uses. Damage to the drone body can cause the drone to be unstable in flight. If the body of the drone is damaged they will need to be replaced.
O que você precisa
Ferramentas
  1. DJI Mini 2 Drone Body Replacement, Battery: passo 1, imagem 1 %32 DJI Mini 2 Drone Body Replacement, Battery: passo 1, imagem 2 %32
    • Face the DJI Mini 2 away from you so that you are looking at the charging ports.
    • Use your finger to open up the back panel.
  2. DJI Mini 2 Drone Body Replacement: passo 2, imagem 1 %32 DJI Mini 2 Drone Body Replacement: passo 2, imagem 2 %32
    • Pinch the locking mechanism on the battery to release the lock.
    • Pull the battery straight out of the compartment.
  3. DJI Mini 2 Drone Body Replacement, Drone Body: passo 3, imagem 1 %32 DJI Mini 2 Drone Body Replacement, Drone Body: passo 3, imagem 2 %32
    • Unfold the wings of the drone.
    • Place the drone upside down on a flat surface.
    • There should be stickers on the device telling you how to unfold the propeller arms.
  4. DJI Mini 2 Drone Body Replacement: passo 4, imagem 1 %32 DJI Mini 2 Drone Body Replacement: passo 4, imagem 2 %32
    • Remove the four 5 mm J000 screws near each propeller arm.
  5. DJI Mini 2 Drone Body Replacement: passo 5, imagem 1 %32 DJI Mini 2 Drone Body Replacement: passo 5, imagem 2 %32 DJI Mini 2 Drone Body Replacement: passo 5, imagem 3 %32
    • Flip the drone back over.
    • Use a combination of the opening tool and your fingers to pry open the top panel of the drone along the seams.
  6. DJI Mini 2 Drone Body Replacement: passo 6, imagem 1 %32 DJI Mini 2 Drone Body Replacement: passo 6, imagem 2 %32
    • Remove the two 5 mm J000 screws located in the battery hatch and near the ports on the back of the drone.
  7. DJI Mini 2 Drone Body Replacement: passo 7, imagem 1 %32 DJI Mini 2 Drone Body Replacement: passo 7, imagem 2 %32
    • Flip the drone over again.
    • Pry off the bottom panel of the drone using the opening tools and your fingers.
Conclusão
8 outras pessoas executaram este guia.
Jacob Matos
Membro desde: 03/25/22
1.167 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team F-1, Gurgel Spring 2022 Membro de UMass Dartmouth, Team F-1, Gurgel Spring 2022
UMASSD-GURGEL-S22SFG1
2 Membros
Autoria de 15 guias
3Comentários do guia
Where to buy a new drone body ?
Loïc Sarda - Responder
Same Q. Where to buy drone body? Please email me. Thanks
Ruud - Responder
Look for it on Google directly or in Amazon there are websites dedicated to sell the hole body parts
Pedro Burgos -
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 60
Últimos 30 dias: 294
Ao todo: 7,528
