Ir para o conteúdo principal
Conair Cord-Keeper 169XR On/Off Switch Replacement
Candace
Candace e 2 outros colaboradores
Última atualização em September 14, 2024
10 minutos
Muito fácil
Introdução
Ir para o passo 1
If your Conair Cord-Keeper 169XR dryer isn't turning on, the back of the On/Off button that engages the power may be broken.
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. Conair Cord-Keeper 169XR On/Off Switch Replacement, Handle Cover: passo 1, imagem 1 %32 Conair Cord-Keeper 169XR On/Off Switch Replacement, Handle Cover: passo 1, imagem 2 %32
    • Unscrew the two 18 mm long Phillips #2 screws on the side of the hair dryer.
  2. Conair Cord-Keeper 169XR On/Off Switch Replacement: passo 2, imagem 1 %32
    • Be cautious of pieces that can possibly fall out when removing the face of the handle.
    • Once you have taken the screws out, take the top half of the handle off by lifting it off of the dryer.
  3. Conair Cord-Keeper 169XR On/Off Switch Replacement, On/Off Switch: passo 3, imagem 1 %32 Conair Cord-Keeper 169XR On/Off Switch Replacement, On/Off Switch: passo 3, imagem 2 %32
    • Now take out the On/Off switch by gently pulling it out towards you and lightly pushing it to the right with your finger until it comes out of the groove it is resting in.
    • Once the new switch is in place you can put the dryer back together.
Conclusão
3 outras pessoas executaram este guia.
Candace
Membro desde: 01/23/14
1.010 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 10-33, Maness Winter 2014 Membro de Cal Poly, Team 10-33, Maness Winter 2014
CPSU-MANESS-W14S10G33
3 Membros
Autoria de 14 guias
3Comentários do guia
Looks to me that a replacement switch would be required. How can obtain one?
Jaky Felix - Responder
“No parts required” is what’s displayed by default when there’s no link to an actual part for sale—it’’s a bit silly and clearly incorrect in this case. For hard-to-find parts, check eBay or Amazon. Also, a lot of folks with multiple broken units use these guides to cobble together one working unit from the parts. Good luck!
Jeff Suovanen -
That was my question, where can I get a replacement switch?
Constance Hudson - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 37
Ao todo: 3,239
