Ir para o conteúdo principal
Canon PowerShot SD780 IS Flash Capacitor Replacement
Arlene Ale
Arlene Ale e 14 outros colaboradores
Última atualização em January 3, 2024
10 - 15 minutos
Moderado
Fotos de ação
Imagens inconsistentes
Despedaçar
Introdução
Ir para o passo 1
This replacement guide will show you how to access the flash capacitor of the Canon Powershot SD780 IS.
Be extremely careful in dealing with the capacitor as it can store a large electrical charge for a long period of time. The safest way to handle a capacitor is by discharging it. You can make a capacitor discharge tool by following the Constructing a Capacitor Discharge Tool guide.
O que você precisa
Ferramentas
Exibir mais…
    • Begin by making sure the camera is turned off and the battery has been removed to avoid any shock injuries.
  1. Canon PowerShot SD780 IS Flash Capacitor Replacement: passo 2, imagem 1 %32 Canon PowerShot SD780 IS Flash Capacitor Replacement: passo 2, imagem 2 %32
    • Having removed the battery, you can begin removing the outermost screws on the camera to allow for case replacement. There are 5 screws in total. This will require a Philips head # 00 screwdriver.
    • Keep track of where each screw came from in order to avoid complications during the reassemble process.
    • The screws highlighted by the red square in the second image (on the left side in the first image) are 2.0 mm long.
  2. Canon PowerShot SD780 IS Flash Capacitor Replacement: passo 3, imagem 1 %32
    • Remove the front panel of the camera case to expose the top left copper strip, and gently pull the strip upward to disconnect from camera.
  3. Canon PowerShot SD780 IS Flash Capacitor Replacement: passo 4, imagem 1 %32
    • Remove the screw on the far left hand side of the camera.
  4. Canon PowerShot SD780 IS Flash Capacitor Replacement: passo 5, imagem 1 %32
    • Now that you have removed all of the screws, carefully pull the case apart at the seem. The case will detach from the camera in two pieces.
  5. Canon PowerShot SD780 IS Flash Capacitor Replacement: passo 6, imagem 1 %32
    • Locate the image stabilizer on the top right of the camera and pry the internal battery away from the camera. Having done this, the internal battery can be removed easily.
  6. Canon PowerShot SD780 IS Flash Capacitor Replacement: passo 7, imagem 1 %32
    • You have now exposed the internal battery, and you may proceed to exchange the old internal battery for a new one.
Conclusão
Uma outra pessoa concluiu este guia.
Arlene Ale
Membro desde: 03/13/14
455 Reputação
Autoria de 4 guias
Equipe
1Comentário do guia
what is the number for the replacement battery?
peterprosser - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 27
Ao todo: 1,011
