Ir para o conteúdo principal
Bose Solo 5 Sound Bar Control Panel Replacement
Emma
Emma e 7 outros colaboradores
Última atualização em October 16, 2024
20 - 30 minutos
Moderado
Introdução
Ir para o passo 1
The following guide explains in detailed steps including pictures on how to replace the control panel of the Bose 5 Sound Bar. The control panel is responsible for controlling the power and the output of the Bose 5 Sound Bar. It may be necessary to replace the control panel if the sound bar does not produce sound when it is plugged into the TV. Upon completion of the control panel replacement, the Bose 5 Sound Bar should work as expected. Otherwise, it would indicate that your system has a different problem.
Before using this guide, be sure to test different audio cables that connect the sound bar to the TV to confirm that the faulty part is coming from the sound bar. Before beginning, make sure to disconnect the sound bar from the TV.
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. Bose Solo 5 Sound Bar Control Panel Replacement, Control Panel: passo 1, imagem 1 %32
    • Lay Bose Solo 5 with speakers facing away from you and bottom side facing upward.
  2. Bose Solo 5 Sound Bar Control Panel Replacement: passo 2, imagem 1 %32 Bose Solo 5 Sound Bar Control Panel Replacement: passo 2, imagem 2 %32
    • Remove the five 18.25mm screws with the Phillips #2 screw driver.
  3. Bose Solo 5 Sound Bar Control Panel Replacement: passo 3, imagem 1 %32
    • Remove the gold plates snap connector from the circuit board by pulling it apart.
  4. Bose Solo 5 Sound Bar Control Panel Replacement: passo 4, imagem 1 %32
    • Using the plastic opening tool, lift the circuit board up and remove from housing.
  5. Bose Solo 5 Sound Bar Control Panel Replacement: passo 5, imagem 1 %32 Bose Solo 5 Sound Bar Control Panel Replacement: passo 5, imagem 2 %32
    • Disconnect the cords running to the white connecter by pulling up on the tab until it is disconnected completely.
    Anyone every found this control board to purchase?
    jdcaldecott - Responder
Conclusão
Emma
Membro desde: 10/05/18
506 Reputação
Autoria de 3 guias
6 comentários
Does anyone know where to buy a replacement logic board? I’ve been searching for a while now, no dice.
Tyler Barney - Responder
hallo und wo bekomme ich das Ersatzteil die Platiene 73252 Delta 3
APP TISCHNER - Responder
Has anyone had any luck finding the same board. Im looking.
ka.wells - Responder
I know how to open it. What I don't know is where to buy one.
szanti - Responder
If anyone was able to find the board, it wuold be great to know where did you find it. Looking for this board during months...
Juan Ramirez - Responder
Aliexpress have the Bose Solo 5 PCB $47
Jason Spring - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 9
Últimos 7 dias: 35
Últimos 30 dias: 107
Ao todo: 14,054
