Ir para o conteúdo principal
Bose QuietComfort 25 Battery Replacement
Matt Jordan
Matt Jordan e 2 outros colaboradores
Última atualização em July 23, 2023
3 minutos
Muito fácil
Introdução
Ir para o passo 1
This guide covers the QuietComfort 25 battery removal and replacement.
Warning. Sometimes, batteries and the compartments they come into contact with can become corroded. Corrosion appears as chalky-white or green. If you see that the battery or battery compartment is corroded, do not allow it to come into contact with your skin or eyes. Alkaline batteries can leak potassium hydroxide, an agent that is capable of burning, corroding, or destroying tissue.
  1. Bose QuietComfort 25 Battery Replacement, Battery: passo 1, imagem 1 %32 Bose QuietComfort 25 Battery Replacement, Battery: passo 1, imagem 2 %32
    • Locate the side designation in the interior of the earpiece.
    • The battery compartment is located on the top of the right-side earpiece, accessible via the latched door.
  2. Bose QuietComfort 25 Battery Replacement: passo 2, imagem 1 %32 Bose QuietComfort 25 Battery Replacement: passo 2, imagem 2 %32
    • Do not allow battery corrosion to come into contact with your skin or eyes.
    • Sometimes, batteries or the terminals they come into contact with can become corroded. Corrosion will appear as chalky-white or green.
    • If the compartment is not clean--coated with debris or corroded--use a cotton swab to carefully remove debris or corrosion from the terminal corrosion.
  3. Bose QuietComfort 25 Battery Replacement: passo 3, imagem 1 %32
    • Insert a new battery.
    • Make sure that the polarity of the battery is aligned correctly to the diagram on the inside of the cartridge.
    anyone know how to change battery on the qc35?
    Gabe - Responder
Conclusão
When finished with this guide process, the Bose QuietComfort 25 should be able to be played with the functioning noise-cancelling feature.
9 outras pessoas executaram este guia.
1Comentário do guia
Are there any option for replacing the latch together with the spring?
I wanted to replace these after a battery leak, but I'm unable to find any sources for the part needed unless you want to buy a full set of headphones from some one else.
Erik - Responder
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 16
Últimos 30 dias: 112
Ao todo: 13,825
