Ir para o conteúdo principal
Boosted Board 1st Generation Remote Battery Replacement
Kevin Manko
Kevin Manko e 4 outros colaboradores
Última atualização em November 30, 2016
15 minutos
Moderado
Guia do aluno destaque
Introdução
Ir para o passo 1
There is nothing more irritating than halfway through your ride your remote dies. Even though today's battery technology keeps improving, batteries eventually die. Luckily batteries are relatively easy to replace.
This guide will instruct you how to properly disassemble your remote and replace the battery. Keep in mind the area around scroll wheel has levers and moving parts inside, so be cautious while opening and closing the remote.
O que você precisa
Ferramentas
Exibir mais…
  1. Boosted Board 1st Generation Remote Battery Replacement, Remote Battery: passo 1, imagem 1 %32 Boosted Board 1st Generation Remote Battery Replacement, Remote Battery: passo 1, imagem 2 %32 Boosted Board 1st Generation Remote Battery Replacement, Remote Battery: passo 1, imagem 3 %32
    • Before disassembling your remote, be sure it is powered off.
    • Remove the four 17.57mm screws from the bottom of the case with a PH0 screwdriver.
    hi my name is Eugene.  I have a question .  My skateboard remote is gone.  remotes are not sold in my country.  what should i do how can i use the skateboard .  we sell remotes from another company.  how can it be adjusted to my boosted mini .  help me solve the issue please.
    Evgeny Bubnov - Responder
  2. Boosted Board 1st Generation Remote Battery Replacement: passo 2, imagem 1 %32 Boosted Board 1st Generation Remote Battery Replacement: passo 2, imagem 2 %32
    • Carefully separate the two halves of the casing by pulling them apart at the seam.
    • Be sure to keep the scroll wheel, lever and buttons attached to the housing.
  3. Boosted Board 1st Generation Remote Battery Replacement: passo 3, imagem 1 %32 Boosted Board 1st Generation Remote Battery Replacement: passo 3, imagem 2 %32 Boosted Board 1st Generation Remote Battery Replacement: passo 3, imagem 3 %32
    • Remove the rectangular black adhesive foam on top of the battery by peeling it away from the battery.
    • Desolder the battery connections from the circuit board.
    • Replace the dead battery with a new 3.7 volt lithium polymer battery.
    • Refer here for more information how to desolder the battery.
Conclusão
3 outras pessoas executaram este guia.
Kevin Manko
Membro desde: 10/06/16
164 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 15-7, Livingston Fall 2016 Membro de Cal Poly, Team 15-7, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G7
4 Membros
Autoria de 6 guias
4Comentários do guia
Where can I get the battery? Or can you give specs? Thanks!
Dan Davie - Responder
You can't use 3rd party remotes with proprietary Boosted products.
Tom Tamaira -
Verified this works with V2 and V3 remotes as well. I did a R29 and it works great. Thank you for the info.
Thayne Christiansen - Responder
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 11
Últimos 30 dias: 58
Ao todo: 5,132
