Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement
Introdução
Ir para o passo 1Follow these instructions to replace a damaged throttle control. Optionally, you may also replace the attached throttle control cable.
O que você precisa
Peças
Ferramentas
Exibir mais…
Use a Phillips #2 driver to remove the two screws securing the throttle control.
While removing the screws, use a 3/8" wrench to counter-hold the lock nuts and prevent them from rotating.
4 outras pessoas executaram este guia.
