Ir para o conteúdo principal
Asus VivoBook X540N HDD to SSD Replacement
Simeon Brankov
Simeon Brankov e 2 outros colaboradores
Última atualização em September 29, 2024
25 minutos
Fácil
Guia colaborativo
O que você precisa
Kits de conserto
Estes kits contêm todas as peças e ferramentas necessárias para executar este guia.
Peças
Ferramentas
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
Exibir mais…
  1. Asus VivoBook X540N HDD to SSD Replacement, Opening the laptop: passo 1, imagem 1 %32 Asus VivoBook X540N HDD to SSD Replacement, Opening the laptop: passo 1, imagem 2 %32 Asus VivoBook X540N HDD to SSD Replacement, Opening the laptop: passo 1, imagem 3 %32
    • First of all you need to remove the 10 screws holding the laptop together.
    • Then use plastic or metal spudger to separate the bottom cover from the keyboard and touchpad assembly.
    • Once you open it, carefully unplug the keyboard and touchpad connectors. Be very careful not to damage them!
  2. Asus VivoBook X540N HDD to SSD Replacement: passo 2, imagem 1 %32 Asus VivoBook X540N HDD to SSD Replacement: passo 2, imagem 2 %32 Asus VivoBook X540N HDD to SSD Replacement: passo 2, imagem 3 %32
    • Once you open it, it should look like this.
    • You need to unscrew the only screw (marked in red) to be able to remove the HDD.
    • When you do that, just unscrew the 4 screws attatching the HDD to the bracket and replace it with the new one.
    Se puede añadir memoria ram ?
    Jorge Gomez - Responder
Conclusão
Simeon Brankov
Membro desde: 11/08/20
7.180 Reputação
Autoria de 54 guias
4 comentários
Pls. Do more tutorial like this. It is very helpful to lack of knowledge person ?..
Would you mind to complete your tutorial regarding disassemble / assemble of this laptop model ?
For example : processor replacement
Heat sink replacement LCD replacement
Battery replacement
Hinges replacement
Thanks In Advance !
More Power !
Gilbert Gutierrez - Responder
Hello,
Im glad that you found the information useful. Unfortunately this laptop is no longer with me, if I come across the same model again, Ill be sure to make a more advanced tutorial.
Thank you and have a nice day :)
Simeon Brankov -
Sorry, I tried to replace it and the bios does not recognize it.
David - Responder
Hello,
This can indicate a problem with the SSD itself and/or the drivers on your laptop. Have you tried to load the drivers manually during Windows installation?
Simeon Brankov -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 52
Duração total: 2,194
