Ir para o conteúdo principal
Asus Transformer T100 Rear Cover Replacement
Taylor Pantiga
Taylor Pantiga e 12 outros colaboradores
Última atualização em January 29, 2018
5 - 10 minutos
Moderado
Precisa de melhores imagens
Introdução
Ir para o passo 1
The Asus Transformer T100 has two main hardware sections: the tablet and the base. This guide will focus on removing the plastic rear cover of the tablet.
O que você precisa
Ferramentas
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
Exibir mais…
  1. Asus Transformer T100 Rear Cover Replacement, Rear Cover: passo 1, imagem 1 %32 Asus Transformer T100 Rear Cover Replacement, Rear Cover: passo 1, imagem 2 %32
    • Separate the tablet from the base by pressing the large silver button below the tablet. The silver button is located at the base of the tablet.
    • Remove the tablet by lifting up.
  2. Asus Transformer T100 Rear Cover Replacement: passo 2, imagem 1 %32 Asus Transformer T100 Rear Cover Replacement: passo 2, imagem 2 %32
    • Insert the opening tool into the seam of the tablet casing and gently pry upwards.
    • With a little force, you will feel the clips release.
    This image seems not to show the correct position where to place the tip of the tool initially. It suggests to pry between the frame and the glass pane from the top of the tablet. That's what I did and broke the glass - one device spoilt. Only the next picture correctly shows where to apply the tool.
    Ole Hoppe - Responder
  3. Asus Transformer T100 Rear Cover Replacement: passo 3, imagem 1 %32
    • Slide the tool along all four edges of the tablet, making sure that all the clips are released.
    • Do not break these clips; otherwise, the screen will become less secure.
  4. Asus Transformer T100 Rear Cover Replacement: passo 4, imagem 1 %32 Asus Transformer T100 Rear Cover Replacement: passo 4, imagem 2 %32
    • Remove the rear casing.
Conclusão
7 outras pessoas executaram este guia.
Taylor Pantiga
Membro desde: 04/14/14
1.617 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 13-31, Maness Spring 2014 Membro de Cal Poly, Team 13-31, Maness Spring 2014
CPSU-MANESS-S14S13G31
3 Membros
Autoria de 6 guias
5Comentários do guia
This is completely wrong. The outside case of the ASUS T100 is brushed metal.
darimini76 - Responder
there is also a white version, so actually not wrong
Jordi Vanwinkle -
Was able to remove the back cover. Needed to unplug the battery and plug it back in so the the Notebook would boot. It now boots perfectly but
when we replace the back cover it snaps in at the sides and bottom but
WILL NOT Snap in on the top (where the power switch is). All tabs on the back cover and the frame are perfect and not broken but the back cover will not snap closed completely at the top. It still powers on but the power switch sticks and have to press near the switch so it releases in the back cover cavity at the top. Anyone have any ideas on this issue. Thanks
ldajnowski - Responder
I had the same problem. Answer is not to start assemble from the top. Instead, start from the side where there is the SD slot or from the bottom end. Then everything will go. Good luck.
Bac Nguyen Ninh -
Take out your Micro Sd card first!! You will snap it in two!
Milk - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 14
Ao todo: 15,844
