Ir para o conteúdo principal
Asus Q503UA-BSI5T17 Hard Drive Removal
Orlando Garcia
Orlando Garcia e 4 outros colaboradores
Última atualização em November 18, 2022
25 minutos
Fácil
Introdução
Ir para o passo 1
The ASUS Q503UA-BSI5T17 is a 2 in 1 touch-screen portable PC with a 15.6-inch screen. This guide will show a step-by-step process on how to remove the hard drive. Removal of the hard drive is necessary if the hard drive begins to fail or dies.
Signs of a failing hard drive are a blue screen error when starting the PC, the PC not starting at all, a “file not found” error when turning on the device , an increase in the amount of corrupted files on the PC, and a loud ticking or scratching sound coming from the device.
Removal of the hard drive may also be necessary to reach other components of the PC or to upgrade for more storage space.
Steps 4 through 6 require handling of the battery and disconnecting it. Make sure the device is completely shut off and unplugged from any chargers or wall ports before working on the device. Be extremely cautious when working with the battery as breaking it can ruin your device.
O que você precisa
Kits de conserto
Estes kits contêm todas as peças e ferramentas necessárias para executar este guia.
Peças
Ferramentas
Exibir mais…
  1. Asus Q503UA-BSI5T17 Hard Drive Removal, Battery Replacement: passo 1, imagem 1 %32
    • Flip the computer upside down. In order to ensure that the correct side is up, you should be able to read the sticker that indicates the serial number on the bottom.
  2. Asus Q503UA-BSI5T17 Hard Drive Removal: passo 2, imagem 1 %32 Asus Q503UA-BSI5T17 Hard Drive Removal: passo 2, imagem 2 %32
    • Remove the ten circled screws along the perimeter of the laptop with a Phillips #0 screwdriver.
  3. Asus Q503UA-BSI5T17 Hard Drive Removal: passo 3, imagem 1 %32 Asus Q503UA-BSI5T17 Hard Drive Removal: passo 3, imagem 2 %32 Asus Q503UA-BSI5T17 Hard Drive Removal: passo 3, imagem 3 %32
    • Starting from the top right corner, use a plastic prying tool to separate the cover from the laptop. Use light pressure to prevent the plastic from breaking.
    • You should feel the frame coming loose. If necessary, use spacers to keep the frame from locking back into place.
    • Repeat the above step around the laptop until you are able to lift the cover.
  4. Asus Q503UA-BSI5T17 Hard Drive Removal, Battery: passo 4, imagem 1 %32
    • Remove the five screws holding the battery in place using a Phillips #0 screwdriver.
    • Screw locations are approximate. If you find screws to be located elsewhere, please update this step with their correct locations.
  5. Asus Q503UA-BSI5T17 Hard Drive Removal: passo 5, imagem 1 %32
    • Disconnect the battery connection.
  6. Asus Q503UA-BSI5T17 Hard Drive Removal: passo 6, imagem 1 %32
    • Grab and lift the battery from the top right-hand side.
    • If all screws are removed, it should come out with no struggle at all.
  7. Asus Q503UA-BSI5T17 Hard Drive Removal, Hard Drive: passo 7, imagem 1 %32 Asus Q503UA-BSI5T17 Hard Drive Removal, Hard Drive: passo 7, imagem 2 %32
    • Once you opened the laptop, the hard drive is located on the bottom right from where the battery is.
  8. Asus Q503UA-BSI5T17 Hard Drive Removal: passo 8, imagem 1 %32 Asus Q503UA-BSI5T17 Hard Drive Removal: passo 8, imagem 2 %32
    • Use a Phillips #0 screwdriver to unscrew the four screws surrounding the hard drive.
  9. Asus Q503UA-BSI5T17 Hard Drive Removal: passo 9, imagem 1 %32 Asus Q503UA-BSI5T17 Hard Drive Removal: passo 9, imagem 2 %32
    • Disconnect the cable that is connected to the hard drive by lifting the edge slightly and sliding it horizontally away from the connector.
    • Remove the hard drive.
    • You may need to further remove the metal mounting brackets from your old hard drive then install them on your new hard drive before reinstallation.
Conclusão
4 outras pessoas executaram este guia.
Orlando Garcia
Membro desde: 08/26/19
359 Reputação
Autoria de 2 guias
Equipe
Gateway, Team S1-G4, Saknee Fall 2019 Membro de Gateway, Team S1-G4, Saknee Fall 2019
GCC-SAKNEE-F19S1G4
4 Membros
Autoria de 5 guias
2 comentários
Very easy to do. Directions were easy to follow.
Roxann Jackson - Responder
Does this laptop have an M.2 nvme SDD slot?
Isaias Perea - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 21
Ao todo: 1,154
