Ir para o conteúdo principal
Acer Aspire E1-510P-4637 CMOS Battery Replacement
Caleb lindsay
Caleb lindsay e 3 outros colaboradores
Última atualização em June 16, 2016
25 minutos
Difícil
Melhor Introdução
O que você precisa
Ferramentas
  • Spudger
    Spudger
  • Phillips #1 Screwdriver
  • Phillips #0 Screwdriver
Exibir mais…
  1. Acer Aspire E1-510P-4637 CMOS Battery Replacement, Battery: passo 1, imagem 1 %32
    • To release the battery, depress the battery release with a nylon spudger. Hold the latch down and slide it over.
  2. Acer Aspire E1-510P-4637 CMOS Battery Replacement: passo 2, imagem 1 %32
    • Firmly grab hold of the battery and slide it out of the laptop.
  3. Acer Aspire E1-510P-4637 CMOS Battery Replacement, Hard Drive: passo 3, imagem 1 %32
    • Remove the M2.5x8 screw with a PH1 screwdriver.
  4. Acer Aspire E1-510P-4637 CMOS Battery Replacement: passo 4, imagem 1 %32
    • Use the plastic opening tool to pop off the small back cover.
  5. Acer Aspire E1-510P-4637 CMOS Battery Replacement: passo 5, imagem 1 %32
    • Use a PH0 Phillips screwdriver to remove the screw securing the hard drive.
  6. Acer Aspire E1-510P-4637 CMOS Battery Replacement: passo 6, imagem 1 %32 Acer Aspire E1-510P-4637 CMOS Battery Replacement: passo 6, imagem 2 %32
    • Use a nylon spudger to slightly pry up the hard drive near the screw holes.
  7. Acer Aspire E1-510P-4637 CMOS Battery Replacement: passo 7, imagem 1 %32 Acer Aspire E1-510P-4637 CMOS Battery Replacement: passo 7, imagem 2 %32 Acer Aspire E1-510P-4637 CMOS Battery Replacement: passo 7, imagem 3 %32
    • Grab hold of the plastic tab and pull the hard drive away from the connectors. This will release the hard drive.
    • The hard drive connector is fragile. Handle with care.
  8. Acer Aspire E1-510P-4637 CMOS Battery Replacement, CMOS Battery: passo 8, imagem 1 %32
    • Remove the fourteen M2.5x8 screws highlighted in the picture with a PH0 Phillips screwdriver.
  9. Acer Aspire E1-510P-4637 CMOS Battery Replacement: passo 9, imagem 1 %32
    • Slide out the disk drive tray.
  10. Acer Aspire E1-510P-4637 CMOS Battery Replacement: passo 10, imagem 1 %32
    • Use the plastic opening tool to gently pry open the laptop.
  11. Acer Aspire E1-510P-4637 CMOS Battery Replacement: passo 11, imagem 1 %32
    • Slowly rotate the back cover up to reveal cables attached to the motherboard.
    • Carefully slide the connectors out of their receptacle to remove the back panel.
    • The connectors are very small and fragile. Handle with care.
  12. Acer Aspire E1-510P-4637 CMOS Battery Replacement: passo 12, imagem 1 %32 Acer Aspire E1-510P-4637 CMOS Battery Replacement: passo 12, imagem 2 %32
    • Open the up the laptop to reveal the CMOS battery.
    • Desolder the CMOS battery to remove it. For soldering help, check out iFixit's soldering guide.
Conclusão
6 outras pessoas executaram este guia.
Caleb lindsay
Membro desde: 04/11/16
778 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 34-15, Maness Spring 2016 Membro de Cal Poly, Team 34-15, Maness Spring 2016
CPSU-MANESS-S16S34G15
4 Membros
Autoria de 6 guias
2Comentários do guia
molto utile e ben fatta, anche se il mio problema è più legato alla alimentazione che pare non funzionare anche senza batteria
Franco Ferrandi - Responder
It'd be really handy if you were to list the model number of the CMOS battery so we can order one in advance.
Dave Compton (SirCompo) - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 70
Ao todo: 17,881
