Acer Aspire A515-51G SSD Replacement
Introdução
Ir para o passo 1Use this guide to replace the SSD on your Acer Aspire A515-51G.
Before you perform this repair, if at all possible, back up your existing SSD. If you are replacing the SSD where your operating system is installed, familiarize yourself with a disk cloning utility so you’ll be ready to migrate your data to the new SSD.
Be sure to completely power off and unplug your laptop. Make sure the laptop is not in standby, sleep, or hibernation mode.
O que você precisa
Kits de conserto
Estes kits contêm todas as peças e ferramentas necessárias para executar este guia.
Peças
Ferramentas
Exibir mais…
Use a Phillips screwdriver to remove the screw securing the HDD hatch on the bottom left of the lower case.
Insert the flat end of a spudger under the cutout on the top right corner of the HDD hatch and pry it up.
Remove the HDD hatch.
Use a Phillips screwdriver to remove the four screws securing the HDD assembly.
Use a Phillips screwdriver to remove the eighteen 6.6 mm screws securing the case.
Insert an opening pick between the lower case and the chassis on the front right edge.
Slide the pick along the front edge to release the clips securing the lower case.
Continue sliding the opening pick along the perimeter of the lower case to release the remaining clips.
Use the pointed end of a spudger to push each side of the battery connector until it comes out of the socket.
Use a Phillips screwdriver to remove the 2.8 mm screw securing the SSD.
Pull the SSD out of its socket and remove it. Keep the SSD as parallel to the motherboard as possible when pulling on it.
Take your e-waste to an R2 or e-stewards certified recycler.
Repair didn't go as planned? Try some basic troubleshooting, or ask our Acer Aspire answers community for help.
2Comentários do guia
WARNING, WARNING WILL ROBINSON!!
Before you remove the lower case, you MUST remove the HDD as it is attached to the lower case. If you pull the lower case up with HDD still attached you will rip the HDD cable off the motherboard. So ...
Unscrew the HDD hatch.
Pull HDD hatch on lower right off carefully.
Unscrew the four black screws holding the HDD assembly to lower case.
Carefully pull the HDD cable off the HDD (careful here, you could rip cable off motherboard).
Carefully pry HDD assembly upwards (with spunger) and remove HDD.
Now proceed with rest of remining steps.
Would someone be able to attach photos to these steps. I don't have the ability to do so, easily.
I used exactly these instructions today to replace the M.2 SSD. Everything worked perfectly. Many thanks for the instructions.
Regarding
@davoesq note - in step 4 of the instructions it is described that the second hard disk, which you can reach directly, must be removed. Care must of course be taken when removing the connector.
