Acer Aspire 5253 RAM Replacement
Introdução
Ir para o passo 1Make sure to remove the battery first to avoid any incidents.
O que você precisa
Now, locate the two screws that hold the back cover panel onto the laptop.
After the panel has been loosened by the plastic opening tool, take your finger, place it in the gap, and remove the panel from the laptop.
Hello. Vous avez oublié de mentionner le démontage du disque dur (une vis) et le débranchement des fils des antennes wifi qui ne gênent pas pour vous lors du démontage de la carte mère.
6 outras pessoas executaram este guia.
1Comentário do guia
which bus-ram acer 5253 can use? i know it use bus 1066 but i don't know with bus 1666 how is machine active?
