ASUS ZenWatch Battery Replacement
Introdução
Ir para o passo 1A simple guide to replace that aging or dead battery in your ASUS ZenWatch.
O que você precisa
On the strap there is a knob. Sliding this knob towards the opposite side of the strap releases the tension on the spring bar, allowing you to pull the strap out..
Use the T5 Torx driver to remove the four screws on the case.
The case will pry easily off with just gentle hand pressure
Ferramenta utilizada neste passo:Tweezers$4.99
Using the tweezers, gently remove the fabric protecting the battery connection.
Use the heavy duty spudger to gently push the contact towards the top of the case.
13 outras pessoas executaram este guia.
6Comentários do guia
Where could i find the modul replacement for asus zenwatch edition (1st editio) the chip body…thanks :) Dave
Dónde puedo adquirir esta batería en Colombia
I want to find a battery for zenwatch 1 plz help i still have a fully functioning zenwatch I don’t want to waste it. (pref na or even better Canadian the shipping is murder)
Looking to get zenwatch 1 battery. Any source recommended by anyone?
Is there still zenwatch 1 battery for sale?
