Ir para o conteúdo principal
ASUS ZenWatch Battery Replacement
Wayne McClure
Wayne McClure e 3 outros colaboradores
Última atualização em May 7, 2024
10 minutos
Fácil
Introdução
Ir para o passo 1
A simple guide to replace that aging or dead battery in your ASUS ZenWatch.
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. ASUS ZenWatch Battery Replacement, Watch Strap Removal: passo 1, imagem 1 %32 ASUS ZenWatch Battery Replacement, Watch Strap Removal: passo 1, imagem 2 %32
    • On the strap there is a knob. Sliding this knob towards the opposite side of the strap releases the tension on the spring bar, allowing you to pull the strap out..
  2. ASUS ZenWatch Battery Replacement, Battery: passo 2, imagem 1 %32 ASUS ZenWatch Battery Replacement, Battery: passo 2, imagem 2 %32 ASUS ZenWatch Battery Replacement, Battery: passo 2, imagem 3 %32
    • Use the T5 Torx driver to remove the four screws on the case.
    • Use the magnetic pad to keep all your parts easily contained!
    • The case will pry easily off with just gentle hand pressure
  3. ASUS ZenWatch Battery Replacement: passo 3, imagem 1 %32 ASUS ZenWatch Battery Replacement: passo 3, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Using the tweezers, gently remove the fabric protecting the battery connection.
    • Take care when removing the fabric. Too much force may damage the contact with the metal tweezers.
    • Use the heavy duty spudger to gently push the contact towards the top of the case.
    what is connector called so joint circuit to battery . if when i purchase in market i do not know it is name please tell me name thanks.
    SKY BIRD - Responder
  4. ASUS ZenWatch Battery Replacement: passo 4, imagem 1 %32 ASUS ZenWatch Battery Replacement: passo 4, imagem 2 %32 ASUS ZenWatch Battery Replacement: passo 4, imagem 3 %32
    • Gently pry the battery up with the plastic pry tools
Conclusão
13 outras pessoas executaram este guia.
Wayne McClure
Membro desde: 02/10/16
961 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 1-3, Sullivan Spring 2016 Membro de USF Tampa, Team 1-3, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G3
4 Membros
Autoria de 7 guias
6Comentários do guia
Where could i find the modul replacement for asus zenwatch edition (1st editio) the chip body…thanks :) Dave
Davy Jones - Responder
Dónde puedo adquirir esta batería en Colombia
Jhon Jairo Piza Puerta - Responder
I want to find a battery for zenwatch 1 plz help i still have a fully functioning zenwatch I don’t want to waste it. (pref na or even better Canadian the shipping is murder)
wing_0_delta - Responder
Hi
im looking for a battery für Asus Viviwatch. Is ist the same as in ZenWatch?
mhoechtl - Responder
Looking to get zenwatch 1 battery. Any source recommended by anyone?
fine_pears - Responder
Is there still zenwatch 1 battery for sale?
Henry Chiang - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 32
Ao todo: 14,211
