Ir para o conteúdo principal
Motorola Moto G 5G (2022) Back Cover Replacement
Clay Eickemeyer
Clay Eickemeyer e 4 outros colaboradores
Última atualização em November 18, 2024
20 - 30 minutos
Moderada
Guia em destaque
This guide demonstrates how to replace the back cover on your 2022 Motorola Moto G.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. Motorola Moto G 5G (2022) Back Cover Replacement, Eject the SIM card tray: passo 1, imagem 1 %32 Motorola Moto G 5G (2022) Back Cover Replacement, Eject the SIM card tray: passo 1, imagem 2 %32
    • Insert a SIM card eject tool or a straightened paperclip into the hole adjacent to the SIM card tray.
    • Press firmly to eject the tray.
  2. Motorola Moto G 5G (2022) Back Cover Replacement, Remove the SIM card tray: passo 2, imagem 1 %32
    • Remove the SIM card tray from the phone.
    • When reinserting the SIM card, make sure it's in the proper orientation inside the tray.
  3. Motorola Moto G 5G (2022) Back Cover Replacement, Back cover removal information: passo 3, imagem 1 %32 Motorola Moto G 5G (2022) Back Cover Replacement, Back cover removal information: passo 3, imagem 2 %32
    • Discharge your battery to 25% or less and completely power off your phone before you begin.
    • Take note of the following seams along the edge of the phone:
    • Screen seam: This seam separates the display panel from the frame. Don't pry at this seam.
    • Bezel seam: This is where the plastic back cover meets the rest of the phone. It's held in place by plastic clips. This is where you should pry.
  4. Motorola Moto G 5G (2022) Back Cover Replacement, Insert an opening pick: passo 4, imagem 1 %32 Motorola Moto G 5G (2022) Back Cover Replacement, Insert an opening pick: passo 4, imagem 2 %32 Motorola Moto G 5G (2022) Back Cover Replacement, Insert an opening pick: passo 4, imagem 3 %32
    • Insert an opening tool in the bezel seam halfway between the bottom-right corner of the phone and the power button.
    • Insert an opening pick in the gap you just created.
  5. Motorola Moto G 5G (2022) Back Cover Replacement, Release the right clips: passo 5, imagem 1 %32 Motorola Moto G 5G (2022) Back Cover Replacement, Release the right clips: passo 5, imagem 2 %32
    • Slide your opening pick toward the bottom-right corner of the back cover and release the clips.
    • As each clip releases, you will hear and feel a pop.
    • Don't slide the opening pick near the power or volume buttons.
  6. Motorola Moto G 5G (2022) Back Cover Replacement, Release the bottom clips: passo 6, imagem 1 %32 Motorola Moto G 5G (2022) Back Cover Replacement, Release the bottom clips: passo 6, imagem 2 %32
    • Continue sliding your opening pick towards the bottom left corner to unclip the bottom edge of the back cover.
  7. Motorola Moto G 5G (2022) Back Cover Replacement, Release the left clips: passo 7, imagem 1 %32 Motorola Moto G 5G (2022) Back Cover Replacement, Release the left clips: passo 7, imagem 2 %32 Motorola Moto G 5G (2022) Back Cover Replacement, Release the left clips: passo 7, imagem 3 %32
    • Slide your opening pick toward the top left corner to unclip the left side of the back cover.
  8. Motorola Moto G 5G (2022) Back Cover Replacement, Release the top clips: passo 8, imagem 1 %32 Motorola Moto G 5G (2022) Back Cover Replacement, Release the top clips: passo 8, imagem 2 %32
    • Slide your pick around the top left corner and along the top edge to release the clips.
  9. Motorola Moto G 5G (2022) Back Cover Replacement: passo 9, imagem 1 %32 Motorola Moto G 5G (2022) Back Cover Replacement: passo 9, imagem 2 %32
    • Slide your pick around the top right corner to release the last clips securing the back cover.
    • Stop before reaching the volume buttons. Your pick may damage their cables.
  10. Motorola Moto G 5G (2022) Back Cover Replacement, Remove the back cover: passo 10, imagem 1 %32 Motorola Moto G 5G (2022) Back Cover Replacement, Remove the back cover: passo 10, imagem 2 %32 Motorola Moto G 5G (2022) Back Cover Replacement, Remove the back cover: passo 10, imagem 3 %32
    • Don't try to remove the back cover all the way yet, as it's still connected to the frame by the power button cable.
    • With SIM card slot facing you, swing the back cover open and away from you like you're opening a book.
    • Rest the cover parallel to the frame.
    • Don't twist the screen or move it too far away from the frame to avoid damaging the power button cable.
  11. Motorola Moto G 5G (2022) Back Cover Replacement, Remove the power button: passo 11, imagem 1 %32 Motorola Moto G 5G (2022) Back Cover Replacement, Remove the power button: passo 11, imagem 2 %32
    Ferramenta utilizada neste passo:
    • A small rubber arm connects the power button to its recess. Use caution to avoid tearing this piece.
    • Use tweezers or your fingers to unhook the power button's rubber arm from its recess and remove it.
  12. Motorola Moto G 5G (2022) Back Cover Replacement, Only the back cover remains: passo 12, imagem 1 %32
    • You're now left with the back cover.
    • This is a good point to test your phone before sealing it up. Follow this guide to perform a hardware test. Be sure to power your phone back down completely before you continue working.
Conclusão
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Uma outra pessoa concluiu este guia.
Clay Eickemeyer
Membro desde: 09/19/22
81.214 Reputação
Autoria de 455 guias
Equipe
Guide Team Membro de Guide Team
Staff
Membros da 9
Autoria de 11.353 guias
Um comentário
What adhesive is used?
Bill Meakin - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 27
Últimos 30 dias: 110
Duração total: 3,414
