Ir para o conteúdo principal
How to Test the Hardware on Your Motorola Phone
  1. How to Test the Hardware on Your Motorola Phone, Open the apps menu: passo 1, imagem 1 %32
    • From the home screen, swipe up from the bottom of the phone to open the applications menu.
  2. How to Test the Hardware on Your Motorola Phone, Open the device help app: passo 2, imagem 1 %32
    • Select the "Device Help" application from the menu.
  3. How to Test the Hardware on Your Motorola Phone, Select device diagnosis: passo 3, imagem 1 %32
    • Select "Device diagnosis" from the menu.
  4. How to Test the Hardware on Your Motorola Phone, Select hardware test: passo 4, imagem 1 %32
    • Select "Hardware test" from the menu.
  5. How to Test the Hardware on Your Motorola Phone: passo 5, imagem 1 %32
    • You can now select which hardware test you would like to run, or you can run a full hardware test.
Linha de Chegada
20 outras pessoas executaram este guia.
Spencer Day
Membro desde: 09/14/22
150.239 Reputação
Autoria de 995 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.649 guias
6Comentários do guia
is built using the open source software libraries listed below. These libraries are distributed under associated licenses, acknowledgements and required copyright notices also listed below:
Michael Lassiter - Responder
Thank you for your help and approval
What if my Motorola phone doesn't have the device help in the app menu then how do I go about running diagnostics on it OH and Just so you know I don't have any mobile data connection so I can't use the phone codes.
Sean Jacob Higgins - Responder
Having problems with my phone
Lisa Jablon - Responder
I want to see how I could take apps off Motorola moto04
Antonio “Mono” Cabrera - Responder
Comentar
Visualizações:
Últimas 24 horas: 19
Últimos 7 dias: 192
Últimos 30 dias: 923
Ao todo: 53,893
