How do I remove the dash trim around the radio?
I have a new/replacement radio form my 2001 Grand Caravan and need to know how to remove the trim to get to the screws that hold the radio to the dash.
Esta é uma boa pergunta?
Obtenha acesso rápido a guias, peças e respostas para seus dispositivos
Tina M, check this video In short, pull the drink holder that exposes a tab min the middle. Press remove the holder. Pull the little plastic piece above it. Its fastened by clips. That exposes two screws. You need a Phillips. After that, carefully pry the plastic facade up to the vents, again fastened by clips. Four screws secure the stereo. hope this helps, good luck.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 4,839
