Ir para o conteúdo principal
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
Desoldering RAM in order to upgrade possible?
Since the MBA, Apple introduced the soldered RAM. I remember someone who tried desoldering it, so he could upgrade it. Now, in the New MBP with Retina display, they did the same. I regret choosing for the 8GB model, because I want to run some Virtual Machines. Is it possible to desolder it, and upgrade the RAM yourself? (even solder the ram again if needed) Can you guys at iFixit maybe try it out?
Thanks in advance!
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Solução escolhida
See if you can return the machine, there's usually a buyers remorse law that says you can for three days and get what you need.
Esta resposta foi útil?
Pontuação 4
1 comentário:
And if you're citizen of the European Union you even get full 14 days.
por
senthor << Only if you bought it online (that is, via a remote shopping facility).
vincent << Often, the store won't turn you down as they prefer a happy customer and an upsale to en unhappy customer and no upsale :)
Pontuação 0
Adicionar a sua resposta
vincent bosch será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 12
Ao todo: 2,770
