Ir para o conteúdo principal
1.4GHz or 1.6GHz Processor / 64GB or 128GB SSD
20 Perguntas Visualizar todos
Not charging, indicator green light
Hi, I have a Macbook Air 11" late 2010 which I recently replaced the topcase/keyboard due to a liquid spill. It was charging before I did the replace but now it just stayed on green and the battery does not charge at all. The battery level before the topcase replacement is at 35% and it has now drained completely. I tried resetting the PRAM and SMC but no effect. Battery cycle count is only 72 and is showing Normal condition in the system report. I tried 3 different power adaptors but still not charging. I wonder which one is faulty, the IO board or the battery?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Download and run Coconut battery. It will let you know if the battery is working properly. http://www.coconut-flavour.com/
Esta resposta foi útil?
Pontuação 2
5 comentários:
Hi Mayer, I am not able to do what you suggested as the battery is completely drained now and it won't power on. The Magsafe supply indicator is showing a green light but it is not charging the battery not even powering on the laptop. I opened the lower case and noticed that the fan started to run when I press the power button but shuts off in a couple of seconds and no power. The laptop sometimes go in a on-off-on-off cycle but does not totally power on the laptop. I tried removing the battery and then plugged in the Magsafe supply but still no power after pressing the power button. Do you think it is the IO board that is faulty? I have tried using a 45W, 60W and 85W supply and no effect at all.
por
Hi Mayer, surprisingly the laptop switched on today and the magsafe indicator turns green to orange. However, it intermittently shutdown itself. I left it charged for 10 hours but the magsafe indicator remains orange and it didn't power on again. I tried removing the battery and power adpater and press power button for 10 seconds then put back the power adapter while pressing the power button for another 10 seconds. Then press the power button again after 2 seconds but it only gives me a high fan spin speed but not starting up the laptop. Any reason why?
por
By the way, I managed to do the coconut battery test before the laptop shuts off. It gives me a good and reasonable results on the battery life.
por
Sounds like it's time to use our guide on liquid damage, tear it down and totally clean it: Electronics Water Damage
por
Hi Mayer, the laptop power on again today and showing orange on the magsafe indicator. The battery is showing 48% and is charging. I noticed that the system runs very slow when on battery only but runs on normal speed when the adapter is plugged in. I finally decided to send it to a repair shop for further diagnosis. I hope it is not a major logic board issue. Do you think?
por
Hello I got this same prob Mayer , I just for ages my MacBook Air and the charger is not charging my pc no more it's only bring a green light after I put the charger and now my battery is drain I really don't know what happen please help me out Mayer
Pontuação 0
1 comentário:
What do I need to do please .. I only figure this out when I formatted my laptop today and when I was trying to charge it's anit working
por
Adicionar a sua resposta
mon será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 6,029
