Ir para o conteúdo principal
Flagship cameras with advanced features first introduced in 2000.
20 Perguntas Visualizar todos
Can my g5x be fixed
Milk got into the lense can it be fixed?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@devorahneustein there are no guides for this camera and I know from experience that disassembling those lenses is almost impossible. I would suggest you install a new lens. Here is the other issue. There are no teardowns listed yet either. Use something like these instructions to get into the camera. Right up to step 16. You would now have to disconnect the lens ribbon cables and should be able to remove the lens. Work slow and be organized while you work on your camera. REmember it is no longer working and whatever you do now can't make it any worse.
While you work on your camera, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Devorah neustein será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Duração total: 10
