Why my computer is failing to start
My computer is failing to start my monitor keeps saying going to sleep
Esta é uma boa pergunta?
There may be a problem with the memory module. It is recommended to replace the memory module. If the cooling fan doesn't turn, it may be too dusty. You need to clean up the dust and then wipe the memory module with an eraser. If the situation is still the same, it is likely that the power adaptor does not work, or the motherboard may have been accidentally dropped and cannot be started.
Esta resposta foi útil?
Related Parts and Tools
Últimas 24 horas: 5
Últimos 7 dias: 24
Últimos 30 dias: 131
Ao todo: 454
