Ir para o conteúdo principal
The Gigabyte GA-990FXA-UD5 is a motherboard manufactured by Gigabyte. Released in 2012. Model number: GA-990FXA-UD5.
Why my computer is failing to start
My computer is failing to start my monitor keeps saying going to sleep
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
There may be a problem with the memory module. It is recommended to replace the memory module. If the cooling fan doesn't turn, it may be too dusty. You need to clean up the dust and then wipe the memory module with an eraser. If the situation is still the same, it is likely that the power adaptor does not work, or the motherboard may have been accidentally dropped and cannot be started.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Ashley Choto será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 9
Últimos 30 dias: 61
Ao todo: 877
