Ir para o conteúdo principal
Nintendo Game Boy Advance, released in 2001. Repair requires only common tools and no heat.
GBA Flickers on and turns off
This GBA Flickers on for a second and powers off. Not sure what the cause is but here's the things I've ruled out.
  1. Capacitors have all been replaced
  2. Battery terminals are clean and bring power
  3. The power switch has been replaced and works
  4. F1 fuse works
  5. There is continuity from F1 -> 101 -> Q5
No idea what it could be so really hoping someone has the answer :) this is the target red edition so I would love to get it revived
-> here is the video on google drive since it wont load properly on here https://drive.google.com/file/d/150N2-g4...
Esta é uma boa pergunta?
Pontuação 0
7 comentários:
Hi @sonrai
Does it do this if you use it with the charger connected to the device?
por
Hey @jayeff this is the original GBA not the SP so there isn't a charger port
por
@sonrai
OK Missed that, sorry.
BTW the video you posted isn't working. Try loading it again.
por
@jayeff all good I put a link to it on google drive since it still wasn't working properly
por
Just to add, this is most of the time caused by a broken Power Switch Solder Pad… please check the solder pads and traces regarding the power switch.
por
Exibir mais 2 comentários
Adicionar um comentário
1 resposta
Hi @sonrai
Not sure if this is the correct one (there's no power jack) but here's the schematic that may be of some help.
Esta resposta foi útil?
Pontuação 0
Related Parts and Tools
Adicionar a sua resposta
Sonrai será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Ao todo: 84
