PC will not boot up
I hit the power button, fans turn a few times but won't start up. Sometimes the RGB lights turn on but nothing else.
Esta é uma boa pergunta?
Obtenha acesso rápido a guias, peças e respostas para seus dispositivos
It’s sounding like your PC is having a power issue. Here are a few troubleshooting steps to attempt:
Check the Power Supply (PSU)
Make sure that the power cable plugged into the wall outlet and into the PSU is firmly in place.
Use an alternate power cable or wall outlet.
If you have a PSU switch (I/O) turn it off and on.
If possible test with another PSU.
Check for a Short Circuit
Turn off and disconnect everything.
Open your case
Esta resposta foi útil?
Well you can try the following:
Your PC may have a power supply, motherboard, or RAM issue. Try these steps:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 37
Ao todo: 102
Hi @zombieslay72601
What is the make and model number of the PC or motherboard if it is a custom build?
por jayeff
