Ir para o conteúdo principal
The Panasonic LUMIX DMC-LX100 is a compact digital camera with 12.8 MP resolution, 4K HD video capabilities, and Wi-Fi access. It was released in November 2014.
Viewfinder blank LCD screen working
I had this problem in reverse. Fixed by resetting to "factory settings", from another similar problem website. which recommended opening up and refixing flat cable between motherboard and screen.
My favourite Panasonic Lumix DMC LX100,:- the viewfinder was working, and could take pictures. But the LCD screen was NOT working, not a glimmer.
Is there a setting, accidentally actioned, that you choose between screen or viewfinder?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @toern
Go to p.55 in the user manual to see how to check that the Eye sensor > LVF/Monitor Switch setting is set for what you want.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
toern será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 38
