Ir para o conteúdo principal
Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
20 Perguntas Visualizar todos
My a button only works when I press down hard
Is there any way to fix it without getting a new motherboard
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi!
Yes there is a way to fix it without replacing the motherboard.
First you need to get the motherboard out, then you will notice that there is a "Conductive pad" for the A,B,X,Y buttons located on the motherboard. Replace that one for a new one and you are good to go!
While you are there, it's recommended to replace the rubbers as well!
Guide: Nintendo 3DS XL Motherboard Replacement (in Step 22 you see the conductive pad already).
Part: https://www.aliexpress.us/item/225183229...
If you need anything else, please let us know!
Esta resposta foi útil?
Pontuação 1
2 comentários:
Thank you I also figure out a another method that doesn't require replacing it by cleaning it with isopropyl alcohol which I just used
por
Yes, it's possible to take out the conductive pad, clean the traces with isopropyl alcohol, then dry it again and put the conductive pad back on. This should also work! But for optimal performance and to make sure that it won't happen soon again, it's recommended to replace it. Good luck with the repair!
por
Adicionar a sua resposta
G Tg será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 8
Últimos 30 dias: 9
Duração total: 45
