Ir para o conteúdo principal
Released in 2017. Identified as model numbers. UX430UA, UX430UQ, UX430UN
Can These Replacement Speakers Fix My Asus ZenBook 14 UX430UN?
Hi everyone,
I’m facing an issue with my Asus ZenBook 14 UX430UN speakers. They’ve become muffled and sound buggy, especially when the volume is set above 10%. It’s really frustrating as I rely on the laptop for multimedia usage.
I’ve come across these replacement options online:
Has anyone tried replacing their ZenBook speakers with similar products? Are these compatible, and would they solve the issue?
Also, if anyone has tips for speaker replacement or recommendations for trusted repair shops, I’d appreciate it!
Thanks in advance!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @fixerjason
Don't know if they would or wouldn't resolve the issue.
What is the audio like when listening through headphones connected to the laptop?
If it sounds OK it may not be the speakers but something else.
Don't know the laptop but can you try adjusting the audio balance in the sound settings to determine if the problem is with the left speaker or right speaker only?
If you want to find other suppliers, search online for either 04072-02370200 or 04072-02370300 to find suppliers that suit you best.
These are the Asus part numbers for the speaker modules that are compatible with your model laptop.
Here's a teardown video that may help to gain access to the speakers.
Important: Ensure that you disconnect the battery from the motherboard, as soon as possible after the back cover has been removed and before commencing any further work inside the laptop. Doing this prevents any chance of electrical damage to the internal components occurring whilst doing the repair. Mechanical or ESD damage to the components is another matter of course. Reconnect the battery last thing before closing the laptop for the last time.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
fixer_jason será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 11
Ao todo: 44
