Ir para o conteúdo principal
Second model camcorder released in 2015. The Panasonic HC‑VX870 has wifi capabilities, 4K resolution camcorder.
Lens cover will not close/open
When I turn it on, the is a sound of a motor in two different pitches, but the lens cover will not open or close. I can manually move it open/close. How can I best service this? Unit is only 5 months old.
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
@edwardalbada "Unit is only 5 months old." it's not covered under warranty?
por
@oldturkey03 apparently not. It was purchased at @BestBuy as "open box". They already gave me a thorough runaround.
por
Adicionar um comentário
1 resposta
@edwardalbada those places are great for giving consumers a runaround :-(
I would try a reset to the factory settings. If that does not work your camera may have issues with the LENS BARRIER DRIVE circuit Check the Panasonic HC VX870 SM
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Edward Albada será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Ao todo: 37
