Ir para o conteúdo principal
Repair guides and support for the 3rd generation Ranger, a compact pickup truck manufactured by Ford.
How to fix doors ajar
My interior light stays on all the time but my door ajar light is on dash how can I fix
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Sounds like one of the door switches has gone bad. Have you checked them? If you want specific information we'll need to know more about your rig; year and particular model would be a good start.
por
2011 ford ranger 5 speed manual transmission and manual door locks. The dome light stays on always and the doors ajar lights on the dash
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @kfs99301
One of the door switches, located in the door lock has gone faulty and is permanently operated i.e. short circuit, even though the door is closed.
You will have to remove and check each door lock to find out which one. You could try spraying some WD-40 into the door lock and see if that resolves the problem.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Kfs será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 20
Ao todo: 33
