Ir para o conteúdo principal
The Dell Inspiron 7306 is a 2-in-1 manufactured by Dell. Specs: Inspiron 7306 2-in-1, 11th Gen Intel(R) Core(TM) i7-1165G7 @ 2.80GHz Processor, 16 GB DDR4 RAM 512GB NVME SSD (not replaceable)
2 Perguntas Visualizar todos
Motherboard Crashed after tech “attempted” to diagnose.
Long story short, my laptop was losing its charge. After getting it diagnosed, I was told it was at the end of its life. If it doesn’t turn on, is it still possible to retrieve its stored data? TIA
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi @jalenahood, there are some ways you can try.
Ideally if the computer is able to boot up to windows,
I would suggest to check and backup bitlocker keys.
https://www.dell.com/support/manuals/en-...
Based on the battery replacement guide, on step 5,
i can see the there is nvme ssd.
Dell Inspiron 7306 P125 Battery Replacement
you can consider getting this usb enclosure
https://www.amazon.sg/ORICO-M-2-Enclosur...
Esta resposta foi útil?
Pontuação 0
2 comentários:
I tried a battery replacement. It no longer turns on. After the replacement it slowly lost its charge and plugging it in does nothing.
por
@jalena
try disconnecting the battery from the laptop and power on the laptop with just the power adapter.
does it works?
por
Adicionar a sua resposta
Jalena será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 10
Ao todo: 17
