Ir para o conteúdo principal
Dell Inspiron 7306 P125 Battery Replacement
O que você precisa
  1. Dell Inspiron 7306 P125 Battery Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron 7306 P125 Battery Replacement, Battery: passo 1, imagem 2 %32
    • Turn off the laptop with the power button and close it.
    • Disconnect any power sources from the laptop.
  2. Dell Inspiron 7306 P125 Battery Replacement: passo 2, imagem 1 %32 Dell Inspiron 7306 P125 Battery Replacement: passo 2, imagem 2 %32
    • Use the Phillips #00 screwdriver to remove the seven M2x4 screws from the back panel of the laptop.
  3. Dell Inspiron 7306 P125 Battery Replacement: passo 3, imagem 1 %32 Dell Inspiron 7306 P125 Battery Replacement: passo 3, imagem 2 %32 Dell Inspiron 7306 P125 Battery Replacement: passo 3, imagem 3 %32
    • Grab a corner of the back cover or use a spudger to lift the cover.
    • Pull the cover up around the edges until it is completely removed.
  4. Dell Inspiron 7306 P125 Battery Replacement: passo 4, imagem 1 %32 Dell Inspiron 7306 P125 Battery Replacement: passo 4, imagem 2 %32
    • Remove the three tapes on the left, middle, and right of the battery.
  5. Dell Inspiron 7306 P125 Battery Replacement: passo 5, imagem 1 %32 Dell Inspiron 7306 P125 Battery Replacement: passo 5, imagem 2 %32 Dell Inspiron 7306 P125 Battery Replacement: passo 5, imagem 3 %32
    • Remove the three M2x3.5 screws that have a screw icon above them with the Phillips #00 screwdriver
    • Do not interact with the object located to the left of the middle screw.
  6. Dell Inspiron 7306 P125 Battery Replacement: passo 6, imagem 1 %32 Dell Inspiron 7306 P125 Battery Replacement: passo 6, imagem 2 %32
    • Pull the battery cable towards the direction of the opening.
    • Do not pull the cable upwards.
  7. Dell Inspiron 7306 P125 Battery Replacement: passo 7, imagem 1 %32 Dell Inspiron 7306 P125 Battery Replacement: passo 7, imagem 2 %32 Dell Inspiron 7306 P125 Battery Replacement: passo 7, imagem 3 %32
    • Insert the new battery. Align the holes of the screwdriver with the center object.
    • Apply the tape from the wires to the battery once more.
    • Ensure that the cover snaps into place when closing the back cover.
Conclusão
Uma outra pessoa concluiu este guia.
Arturo Gonzalez
Membro desde: 03/29/23
172 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 19
Últimos 30 dias: 68
Duração total: 550
