Ir para o conteúdo principal
On 11 June 2014, Nissan unveiled the third generation Navara (now known as the NP300 Navara) and is codenamed D23. The D23 will not be available in the US.
My air conditioner is not working
Why is my air conditioner not working
Esta é uma boa pergunta?
Pontuação -1
1 comentário:
1. car not running
2. broken drive belt
3. bad clutch
4. broken wiring
5. bad switch
6. refrigerant leaked out
7. air director not working or stuck
8. bad compressor
9. plugged up refrigerant lines
You need to see an HVAC mechanic.
por
Adicionar um comentário
1 resposta
Generally the first thing to check is the refrigerant pressure, the best way is to test it is via an OBD tool, the second thing is the AC clutch that engages the compressor, you can hear it when you turn on the AC but it works only if the there's a refrigerant to begin with.
So check if you have enough pressure inside the circuit.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Melissa será eternamente grato(a).
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 12
Últimos 30 dias: 22
Ao todo: 109
