Ir para o conteúdo principal
The Latitude E7440 is an ultrabook by Dell released in November 2013, identified by model number 730-6964, with a fully usable touchscreen display. It is a high end business laptop built to be portable and sleek yet sturdy.
16 Perguntas Visualizar todos
Ivalod partition and error pxe e61
Invalid partition table!
Intel(R) Boot Agent GE v1.5.50
Copyright (C) 1997-2013, Intel Corporation
PXE-E61: Media test failure, check cable
PXE-MOF: Exiting Intel Boot Agent.
No Boot Device Found. Press any key to reboot the machine_
From dell lattitude e7440
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
@ukomfarmasi Enter your computer's BIOS and check if your computer's HDD still shows. This error is the most common error when you have a failed HDD. It can't find the OS, so it's moving down the list to other possible boot devices until it finally displays the No Boot Device Found.
To enter the BIOS, power on the system and then go to BIOS Setup by pressing the F2 key.
You can quickly verify this by setting the boot order to USB and create a bootable USB drive. Then start your computer from that. If it properly functions, you know you will have to replace your HDD.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
UKOM Farmasi será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 10
Duração total: 29
