Ir para o conteúdo principal
The Acer Aspire is a laptop manufactured 2014 by Acer catering to the casual household and small business
5 Perguntas Visualizar todos
Laptop tiba-tiba layar gelap screen suddenly goes black
Bagaimana caranya memperbaiki laptop Acer yang layarnya tiba-tiba gelap tidak kelihatan namun Masi menyala
Translation Indonesian - English
How to fix an Acer laptop whose screen suddenly goes dark and can't be seen but is still on
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@anharthyo the repair will spend on what has failed. Do a little bit more troubleshooting.
Turn the computer on to the point where you know it is on. Next, use a flashlight and shine the beam at an angle against the screen. Do that in a darkened room. See if you can make out shadows or shapes. If you do, then it is your backlight that has failed.
If you do not see anything, it is possible that this is a GPU issue or an issue with your graphics circuitry on the mother board. To test that, connect an external monitor. If that shows porphyry, then you know the issue is with your LCD. Let us know what you find out.
Translation
@anharthyo perbaikan akan menghabiskan apa yang gagal. Lakukan sedikit pemecahan masalah lagi.
Nyalakan komputer hingga Anda tahu komputer itu menyala. Selanjutnya, gunakan senter dan sorotkan sinarnya dengan sudut menghadap layar. Lakukan itu di ruangan yang gelap. Lihat apakah Anda dapat melihat bayangan atau bentuk. Jika ya, maka lampu latar Anda yang mati.
Jika Anda tidak melihat apa pun, mungkin ini adalah masalah GPU atau masalah dengan sirkuit grafis Anda di motherboard. Untuk mengujinya, sambungkan monitor eksternal. Jika itu menunjukkan porfiri, maka Anda tahu masalahnya ada pada LCD Anda. Beri tahu kami apa yang Anda temukan.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Anhar Thyo será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 27
