How to update BIOS of C50-B?
I cannot update BIOS from 1.30 to5.10. Please help me.
Esta é uma boa pergunta?
What have you tried so far?
Did you read this?
Toshiba Satellite C50 BIOS update
Secure boot and CSM boot setting is important.
The boot menu key is either F12 or F2.
Esta resposta foi útil?
I disabled secure boot and enabled csm boot,still no response,It shows ec id check failed
1.) Did you reset the BIOS by removing/disconnecting the CMOS battery? It could be corrupted.
2.) https://support.dynabook.com/
and type in your serial number just to double check you have the correct BIOS version for your exact laptop model.
3.) Did you format the USB flash drive with FAT 32?
Yes I did,My model does not have CMOS battery
There is a CMOS battery on the motherboard.
It is a rechargeable battery that is soldered onto the board.
Look for JRTC component on the board
You can also clear the cmos (BIOS) by short circuit on jumper pads JP1 & 2 near the ram door, for about 10 seconds
Does csm os can help update bios
Gear Up For Future Repairs
Shop allWell I will suggest you to check out the following video: https://www.youtube.com/watch?v=oKpBB31R...
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 48
Ao todo: 591
1 comentário
I had disabled secure boot and enabled cam boot.Still it shows error,ec id check failed
por Joel Joseph
