Ir para o conteúdo principal
The Sony Cyber-shot DSC-HX400V is a hyperzoom bridge digital camera that features a 20.4-megapixel Exmor CMOS sensor and 100-times digital zoom.
Is there an internal battery?
My camera will no longer turn on or display a menu with or without a charged battery and plugged into usb charging. Is there an internal battery that might need to be replaced and how would I go about doing that?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
I have this problem too. Were you able to change the battery and did it fix the issue?
por
Adicionar um comentário
1 resposta
Solução escolhida
@dwjohnson30243 yes, it does. Sony part number for that is 1-756-710-12 and it looks like this
It is soldered to the mainboard
Use something like this teardown Sony Cyber-shot DSC-HX400V Teardown to get to it :-)
Esta resposta foi útil?
Pontuação 1
2 comentários:
Soldered? So Sony doesn't consider this user replaceable?
por
@dwjohnson30243 Nope! OEM's do not consider anything user replaceable if they can make a buck on it.
por
Adicionar a sua resposta
DWJohnson será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 23
Ao todo: 215
