Ir para o conteúdo principal
Sit-on-top lawn mower. Zero-turn radius mower, 50" mower deck, hydro transmission.
Help with blown engine
Will a 24 OHV Intek off a craftsman riding mower fit a zts 7500 with a 26 hp v twin
Esta é uma boa pergunta?
Pontuação 0
1 comentário
@marshaljohnson would that be a Intek V-Twin Cylinder OHV
por
Adicionar um comentário
1 resposta
Solução escolhida
@marshaljohnson we would need to have the actual engine numbers so we can try and compare the engines. Number one issue will be the crankshaft size. If those are different, you would need to manufacture an adapter. It might fit but doubt that this will be a simple drop in. I am sure it could be made to fit but may require some manufacturing.
Esta resposta foi útil?
Pontuação 0
Gear Up For Future Repairs
Adicionar a sua resposta
Marshal Johnson será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 19
Ao todo: 92
