Minha bateria não tá carregando
Minha bateria não está carregando
Esta é uma boa pergunta?
Obtenha acesso rápido a guias, peças e respostas para seus dispositivos
@joanitamiranda check it just like you would check any other phone that is not charging.
First check your charger. Make sure it has proper output. Then check your charging cable. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a USB ammeter and see if your phone draws any amperage from the charger. If it does not it is possible that this is a charging port issue or a bad battery.
To check the charging port, use a voltmeter and measure the voltage on your battery connector. Next plug your phone charger in. Now measure the voltage on your battery connector. That voltage will have to have increased. IF not then the issue is either the port or the charging circuit.
Your phone uses a soldered charging port on the mainboard. You will have to check on there if the voltage from teh charger makes it to the main board. Failure of the charging port is common issue with these phones.
Since iFixit does not yet have a guide for this, use something like this video
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@joanitamiranda Verifica-o da mesma forma que verificarias qualquer outro telemóvel que não esteja a carregar.
Primeiro, verifica o teu carregador. Certifica-te de que tem uma saída adequada. Utiliza um carregador para o carregar e não um computador, etc. Depois, verifica o cabo de carregamento. Verifica se os conectores não estão dobrados, etc. Depois disso, verifica a porta de carregamento. Limpa-a de quaisquer detritos, etc. Utiliza alguns sopros de ar para a limpar. Se nada disto funcionar, arranja um amperímetro USB e vê se o teu telemóvel consome alguma amperagem do carregador. Se não conseguir, é possível que se trate de um problema na porta de carregamento ou de uma bateria avariada.
Para verificar a porta de carregamento, utiliza um voltímetro e mede a tensão no conetor da bateria. Em seguida, liga o carregador do telemóvel. Mede agora a tensão no conetor da bateria. Essa tensão terá de ter aumentado. Se não aumentar, então o problema é a porta ou o circuito de carregamento.
O teu telemóvel utiliza uma porta de carregamento soldada na placa principal. Terás de verificar se a tensão do carregador chega à placa principal. A falha da porta de carregamento é um problema comum nestes telemóveis.
Como o iFixit ainda não tem um guia para isto, usa algo como este vídeo
Enquanto trabalhas no teu telefone, tira muitas fotografias. Quando terminares, tira essas fotografias e cria um guia para o iFixit. Isso irá ajudar a próxima pessoa que tenha um dispositivo com os mesmos problemas que tu. É fácil e divertido criar estes guias. https://ifixit.com/Guide/new A comunidade iFixit vai agradecer-te.
Reparar é uma guerra contra a entropia!
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 48
