How to repair leakage in water piepline?
In my outdoor water pipeline there was a leakage and i don't understand how to fix it without changing the whole pipeline??
Esta é uma boa pergunta?
Pontuação
0
Obtenha acesso rápido a guias, peças e respostas para seus dispositivos
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 44
Hi @mohityogi,
What is the pipe made of, pvc plastic, LDPE poly, copper, G.I. (steel) etc?
Can't you cut out the section where the leak is, and simply replace a small section of the pipe using the appropriate fittings?
por jayeff
The pipe is made of PVC plastic. Can you pls suggest me how can i do this small saction fitting and which are things that are used to do this?
por Mohit Yogi
@mohityogi post some pictures of where and what this damage looks like. PVC is easily fixed, if you are in an area where you can purchase the right repair parts :-) Adicionar imagens a uma pergunta já existente
por oldturkey03
