Ir para o conteúdo principal
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
20 Perguntas Visualizar todos
Battery will not charge, but works on AC
My MacBook has had water damage. but i works with ac. The battery will not charge. It will either say it is change for like 5 minutes and stop. Or it will show that there is no battery in.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
The MacBook logic board charging area (left side of the logic board) is very sensitive to liquid spill. We see many machines that still works after a liquid spill but battery charging function is often altered. If you have no success with a known working battery after replacing the battery charging board then the logic board need to be replaced or repaired. A repair will cost you at least $200 if the logic board can be repaired
Esta resposta foi útil?
Pontuação 3
It could very well be the Magsafe board that is not charging:
MacBook MagSafe DC-In Board
http://shop.ebay.com/i.html?_kw=A1181%20...
or as in my case I changed the battery cable which contains some electronic that could be damaged by liquid. This cable tells the logic board if the battery needs charge, is present at all etc. Here it is:
MacBook Battery Connector/Sleep Sensor (non-Energy Star)
Just remember to get the correct version for your MB.
Imagem de Provides battery contacts and sleep sensor for logic boards without Energy Star printed at the second RAM slot.
Produto
$7.99
Imagem de Replace a broken or damaged MagSafe DC-in board for your MacBook with this part. This part connects the wall adapter power to the logic board.
Produto
$19.99
Pontuação 0
Adicionar a sua resposta
Zack será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 11
Duração total: 14,523
