Ir para o conteúdo principal
The Toshiba Satellite CL15t-B1204X notebook is an entry level Toshiba laptop made in 2015. It uses a small form factor with an 11.6" screen and a sleek silver chassis.
3 Perguntas Visualizar todos
Can I upgrade ram on this device is it possible?
I want to know what type of ram this laptop uses and if it is anyway to upgrade it.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @anthonycal58271
Short answer is no you can't.
According to the specifications it is non upgradable which usually means that it is soldered to the motherboard.
As the storage is also hard mounted eMMC type it means that you're stuck with what you got.
You could always increase the storage by inserting the largest capacity SD card that you can afford or want, into the laptop's card reader port and leave it there, configured as the 2nd storage drive.
By this I mean that you make the existing eMMC storage i.e. C: drive the drive that stores the OS and any programs and you move and point the data files i.e. Documents, Download, Pictures Videos files etc to the SD card drive i.e. you name the drive G: or R: etc.
Doing this has its advantages as your data is easily accessible (retrievable) in the event of the laptop failing and you haven't got a recent backup, simply remove the card from the reader port and insert it into another card reader connected to a computer. It is unobtrusive as it is flush with the case so it won't be in the way.
A disadvantage is that it being easily accessible, it is not as safe from theft if you happen to leave the laptop unattended for a short while in a public place, but others would have to know that the card is there in the first place. I won't tell its there if you don't ;-)
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Anthony Calvasina será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 66
