Ir para o conteúdo principal
The HP Elite x2 1012 G2 is a keyboard and tablet device released by HP in July of 2017 .
What wwan cart is compatible with this model?
I have this used model and it doesn't have a installed wwan card but have antenna connections and a sim cart slot. I'm thinking of installing new wwan card here but is Modem WWAN HP LT4120 Snapdragon X5 LTE Modem 4G and only wwan card accepted here?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @konradkadej
I don't know but looking at the maintenance and service guide for the laptop - see p.40, the HP part numbers for the WWAN cards that are used are either not available or most of them support 3G only.
You could try using a different M.2 42mm B key WWAN module and see if that works but finding the drivers that are compatible with the laptop BIOS may be a problem.
Esta resposta foi útil?
Pontuação 1
2 comentários:
I didn't read the hp manual because it looked like it wasn't updated 2017 (too old).
I also ignored this answer and installed this card anyway.
Now this tablet asking me for Sim card, so it works for me.
I don't know if it will work for anyone since I have found and read that there are few versions of this hp tablet not yust Sim and not Sim versions like USA , EU and the rest of the world.
My geas is that if you have a slot and not fake Sim card tray, it could work 🤔
por
I have same issue, there's a slot and space for a wwan card. Which card did you install.
por
Adicionar a sua resposta
Konrad kadej será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 7
Ao todo: 131
