Ir para o conteúdo principal
Repair guides and support for USB flash drives, also known as jump drives, USB sticks or thumb drives.
20 Perguntas Visualizar todos
USB Not detecting to pc
When I connect my USB flash drive to my PC, it doesn't show any data. "Please insert a disk into a USB drive (D:)" is the message that appears.
Esta é uma boa pergunta?
Pontuação 2
1 comentário:
Hi @rajeshgore43720,
Does the USB flash drive work OK when connected to other computers?
por
Adicionar um comentário
1 resposta
I've had this before, when the USB was formatted as a Linux install. Most likely that the drive isn't formatted correctly. In Windows 10 File Explorer, you should be able to right click on the drive and format it to ExFAT for general file use (this will erase what is on it). This could also be happening due to damage to the drive. It would help to know what the drive was used for before this happened.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Rajesh Goregaonkar será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 72
