Ir para o conteúdo principal
A midrange Realme phone, released in September 14th, 2020. Powered by Snapdragon 720G and up to 8 GB RAM with 128 GB on-board storage, also has a 6,4" Super AMOLED screen.
My mobile screen problem
my mobile screen problem
Update (01/24/24)
my display line shown new update
Esta é uma boa pergunta?
Pontuação 6
11 comentários:
My mobile display is not working
por
@realme17135 have you done anything as suggested in the Answer?
por
Phone screen broken and not working properly
por
@shashikant14440 not enough information to be certain but if you have issues similar as the original question, do the same as suggested in the original answer. Replace the display.
por
Phone work nhi Kar rha Hai
por
Exibir mais 6 comentários
Adicionar um comentário
1 resposta
@realme7pro sounds like you are saying that your phone display shows lines. That can be caused by either a bad display or by a bad connector and circuit board. I suggest that you start with a new display.
Since ifixit does not yet have a guide for this, use the one from here It is in Spanish but your browser should have no issues translating it. Replacement screens are available at many online stores. Do a search for it within you region.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Esta resposta foi útil?
Pontuação 0
7 comentários:
Can't touch the screen. How to Fix It
por
@harithmage what make and exact model is your phone?
por
Display change
por
@vedansh the same way as in the original answer.
por
My phone died 😞
por
Exibir mais 2 comentários
Gear Up For Future Repairs
Adicionar a sua resposta
REALME 7 PRO será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 23
Últimos 30 dias: 72
Ao todo: 3,040
