Ir para o conteúdo principal
Samsung's third iteration of the Galaxy Watch with a newly integrated BioActive Sensor. It was released August 27th, 2021. Model SM-R860, 40 mm, non-LTE version.
19 Perguntas Visualizar todos
Brand new Galaxy Watch 4 doesn't turn on
Just arrived a brand new Galaxy Watch 4 Classic and when I tried to turn on I had the surprise that it just doesn't show any signal (vibration, sound, screen,...).
Then I tried to charge for a while it and no signal too, it got a little hot on the back after some time but just it.
What could I do to turn it on?
Esta é uma boa pergunta?
Pontuação 1
1 comentário
I tried to put and pull on the charger multiple time and somehow it started showing life signs... Let's see the upcoming
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @felipebraz35835
If it is brand new and after charging it, it should work.
If it's not indicating that it is charging or that it's not turning on, contact the seller about a refund or a replacement.
The watch has a 12 month manufacturer's warranty if the seller won't co-operate so contact Samsung customer support in your location about a warranty replacement.
Do not try to open it to find out what's wrong as you will void the warranty.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Felipe Braz será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 304
