Ir para o conteúdo principal
How to adjust hinge?
Laptop hinge has been getting looser over the past 1.5 years. Have not attached anything to the back of the laptop such as to add weight to the display which hinges. Need a guide which shows what screws(if any) to tighten.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi @gyratinghe82445
Here's the service manual for the laptop that will help.
Go to the bottom of p.49 to view the procedure to remove the display assembly. This will allow you to check the hinge screws that are screwed into the screw mount in the base enclosure (see images 5 & 6 p.50-p.51).
On p.68 it shows how to remove the hinges from the lid cover.
Esta resposta foi útil?
Pontuação 1
Related Parts and Tools
Shop all
Adicionar a sua resposta
Gyrating_Helicopter será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 16
Ao todo: 166
