Ir para o conteúdo principal
Keyboard Replacement for OMEN 16
Is there a guide for replacing a keyboard on an OMEN 16 C0000
Esta é uma boa pergunta?
Pontuação 2
2 comentários:
Where can I get the keyboard replacement part
por
@sergiobonilla
What is the full model and product number of your laptop as shown on the product information label on the bottom of the laptop?
por
Adicionar um comentário
1 resposta
HP actually provides documentation for this on their support site in PDF form: available here. The keyboard assembly is part of the top case, not including the trackpad, so you will have to remove and completely disassemble the laptop to replace it. From the maintenance and service guide PDF, start at page 30 and follow each section through to page 60 which will guide you through the disassembly of the laptop and the final section give the replacement part numbers for the keyboard assembly.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
ann._.ika será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 67
Ao todo: 740
